BFG Tech GeForce GTX 260 OCX Maxcore
Written by Tim Smalley
September 25, 2008 | 12:02
Tags: #216 #260 #4870 #bfg #core #evaluation #geforce #gtx #hd #max #maxcore #ocx #overclocking #performance #processor #radeon #review #scaling #shader #stream
Companies: #bfg-tech #test
Power Consumption
On top of our graphics performance testing, we’ve also measured the power consumption of the tested graphics card at both idle and load. For this we used the same systems that we have used for our 3D performance testing.
For our idle testing, we left the cards idling on the desktop for ten minutes, recording the average draw at the wall socket. For load testing, we used our benchmark routine from Crysis in DirectX 10 mode and measured the peak power consumption throughout the benchmark. We tested the cards in a number of other scenarios and this proved to be the most intensive in all cases, so you can consider this to be a worst-case scenario.
Bear in mind that we have disabled all CPU-related power management options in the motherboard's BIOS so that we can highlight exactly how well the GPU's power management features are working (or not).
Idle Power Consumption
Windows Vista Desktop (Aero Enabled)
  • ATI Radeon HD 4850
  • Nvidia GeForce GTX 260
  • Nvidia GeForce GTX 280
  • BFG Tech GeForce GTX 260 OCX Maxcore
  • Nvidia GeForce 8800 GT
  • ATI Radeon HD 3870 X2
  • Nvidia GeForce 9800 GTX+
  • ATI Radeon HD 4870
  • ATI Radeon HD 4870 X2
  • 182.0
  • 182.0
  • 189.0
  • 190.0
  • 194.0
  • 194.0
  • 202.0
  • 219.0
  • 223.0
100
150
200
250
Watts (lower is better) - Average Reading
Loaded Power Consumption
Crysis DX10 at 1680x1050 0xAA 0xAF
  • 285.0
  • 295.0
  • 320.0
  • 326.0
  • 333.0
  • 349.0
  • 364.0
  • 387.0
  • 483.0
200
300
400
500
When you combine the increased clock speeds with the higher stream processor count on BFG Tech's GeForce GTX 260 OCX Maxcore, you end up with a card that uses more power than a reference GeForce GTX 280 at idle, and one that's 23W thirstier than a standard GTX 260 when its fully loaded. These results don't surprise us in many ways - it's to be expected given what BFG Tech has done with the card.
